Air Con......any tips, it's not working!
We're in Spain for another couple of weeks, it's been 27c today, pressed the air con button to chill the air and it didn't make a blind bit of difference
Any ideas, or is it a trip to an aircon specialist or to the dealer when we get back home.......the cars only 18 months old
Regards all
Juan
Sent from my iPhone using my thumbs
Wow, thats pretty early for an air con fault. Dealer time under warranty then!!
Checked all the fuses for air con, do your radiator fans kick in when the air con is on?
Hi there, I've just looked the manual and it states in there to check the fuses, all the ones relating to aircon control other things as well, all of which are working.
Havnt checked the fans, I'll take a look in the morning, just had a few beers!!
Juan
Fuses are all OK
No fans kick in when the aircon is turned on.....
Regards all
Juan
It's not unusual for the compressor to fail. When mine did in the vrs it took the aux belt with it meaning a ground to a halt after 30 miles or so.
Pop the bonnet and it's right behind the drivers headlight (at least it was on my cr170). If you sew a pin sticking out the side it's goosed.
Sent from my Samsung Galaxy Note 2 using Tapatalk
I've done about 300 miles since finding it doesn't work.
Aux belt is good and taut and looks fine, no pins I can see sticking out of the compressor
Regards all
Juan
Edited by Its me
