Ecs n75 are they worth the money
Hi guys just wondered if these are worth the money as i have a hesitation problem at midrange during 3rd 4th and 5th so hoping this could fix it
  • Replies 50
  • Views 3k
Youve got an underlying issue with something else, this wont fix it...
I've done abit off reading could be this or my secondary air pump
No point in changing it to anything other than a new stock one really mate.
Im also interested in this as i have a similar fault
I thought the ecs were better than stock ?
I have the ECS race valve and it completely fixed my hesitation, but i had a remap. These work well on some remapped cars. They tend to cause boost spiking on std cars and some mapped cars.
I would not suggest you fit a race N75 valve on a std mapped car as mentioned you must have a underlying issue that needs fixing that perhaps a std N75 may cure.
Hi my car has a revo map stage 2 and I've only noticed this over the last few weeks I've changed the maf and cleaned throttle body which has helped slightly
What do u have mark ?
What does it do ?
:D do i want one ? Lol
What does it do ?
I bet you do buddy.... You can make it shinny..
This i the Actual ECS site and details (if you buy from USA)
You can read there claimed details :
http://www.ecstuning.com/Volkswagen-Golf_IV--1.8T/Search/N75/ES122/
Race N75 Frequency Valve
Volkswagen Golf IV 1.8T
The absolute quickest & most inexpensive way of getting more HP out of your turbocharged VAG product
The N75 is the VW/Audi part identification number for the wastegate by-pass regulator valve. This valve is responsible for controlling the movement of the pneumatic actuator which drives the wastegate. The wastegate is an internal valve in the turbo-charger which controls the amount of exhaust gas that flows over the turbo impeller generating boost.
Under normal operating conditions the engine's ECU sends signals to the N75 valve asking it to open or close, which adds or reduces pressure on the wastegate actuator. This results in more or less boost. The ECS RACE N75 valve modifies the normal operating parameters of the original N75 valve by delaying the speed at which these ECU signals are interpreted. The result is a higher initial peak boost and an elevated boost curve which tapers back to stock/chipped levels over the engines rev range.
Average boost gains are 1-3psi over the rev band.
Or buy here from Awesome UK.
http://www.awesomegt...ency-valve-1-8t
Like I mention though some mapped cars and std cars don't like them.
mine does....
Ooooo :) i wonder if stage 2 revos will like it
I going to try and I'll let u know cous
:) sweet
Then i'll add to my list lol
My old REVO stage 2 did and my new Shark map does too... :rofl:
Another £90 to burn then :D
Does at least make a funky noise or anything lol
Defiantly getting one then
Hehe feel free to get 2 :D lol
I can see if we can get discount if u want one bud
Whats that.... Buy 1 get 1 :D
Yeah I wish bud if only
Ok just brought one hopefully works with my revo map
:) we shall see
If it does you will be wanting one ;)
It has to wait its turn
I have a few projex on the run lol
