Weird central locking fault.
My car has developed a fault with the central locking,over the last 2 months it has on two occasions unlocked & locked the doors whilst driving along,ive also noticed that when you switch the car off the radio goes off & doors unlock,it only used to do this when the key was removed,im wondering if the ignition switch is faulty?
mine does it too.... When I take out the key from the ignition switch the radio goes off and car unlocks itself....
Regards
Have you tried using your spare key to see if the fob is faulty (new battery required?). May be worth looking in your maxidot to see what settings you've got for the central locking too.
cheers
That doesnt sound right, with anti hijack enabled the doors should definitely not unlock and lock whilst in motion; also you are quite correct in that the doors only unlock when the key is pulled from the ignition (or you pull a door handle twice).
Id get it looked at.
Ours is having the exact same problem.
It's at the dealers now. They identified a fault with the ignition switch which they replaced... they broke the ignition barrel while doing this though so waiting for a new one to arrive.
Will let you know if it solves the problem.
Phil
Thanks phil,i have ordered a ignition switch & will fit it next week,will let you know if it fixes mine! :rofl: I wonder how they broke the ignition barrel?? mind you this is D M kieth we are talking about. :wonder:
Haha.
Something about a pin falling out that they couldn't get back in.
Phil
I replaced my ignition switch tonight & it has fixed the radio/un locking problem,time will tell if its fixed the locking/unlocking as you drive along.
good result :thumbup:
