O2 sensor problem or heating circuit problem ?
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Control Module Part Number: 06A 906 032 SG
Component and/or Version: 1.8L R4/5VT G 0010
Software Coding: 11500
Work Shop Code: WSC 73430
Additional Info: TMBELH1U06A011743 SKZ7Z0F3660259
VCID: 75EF30404F517BB002A
2 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-00 - Open Circuit
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-00 - Performance too Low
My mk1 vrs throwing this error. the issue surfaced when i revved the engine a bit hard to negotiate with the steep incline and wheel spun a bit. cleared the code only to watch it come back following day. waited for the tank to get near empty and tanked up just to be sure its not a bad fuel temporary issue. cleared fault codes again. jacked it up and disconnected and connected the electric cable connectors inside the blackbox which is connected to both the sensors.
If this is a sensor problem Can someone let me know if the sensor comes along with heater circuit or do i have to buy it seperately.
As far as I know its just the o2 sensor it comes with the heater built in. Iirc S1 is the pre cat one. Get a genuine or bosch one to replace
the heater element is built into the tip of the sensor, so as far as you are concerned it is just one integrated unit.
Thank you david. Going by colin's 'useful part no' thread, OEM cost is 120 £ at skodaparts.uk and bosch is just about 54 $. know a better place to source oem ?
I couldn't say going by your location sorry mate.
I will have it shipped from uk. Someone visiting me will carry along or will come through post
