Dreaded hiss behind dash
Hi all,
As per the title only noticed it the other day when radio was off. Turn Econ off and I can hear it not so much it's a gaping hole but like any type of pressurised pipe, water running through central heating pipes type noise.
Anybody aware of the cause/fix
Steve
Low refrigerant in the AC system?
Sent from my HTC One X using Tapatalk 4 Beta
Low gas, just about to run out. Mine has done the same. Leaking from the condenser.
Mine was making that noise and it needed a new condenser/seals.
Oh bugger! Last check on VCDS showed the system @6.2 bar with a little rev, 42% compressor load at idle and evaporator temp of 22-23c. Is there any measuring block for refrigerant level?
Also strange was coming home from work tonight and Econ was off climate set to 16c as its quite humid where I am, blowing warm-ish air so for some reason turned Econ off and it started blowing cold and I mean cold even with ambient temp of 16-16.5c?? Anyone any ideas??
