After sale Bi-xenon mount
Bi-xenon is extremely expensive here in Denmark (like £2.200) , so I wondered if it is possible to buy original xenon lights somwhere and mount the bi-xenon myself.
Secondly, is it a plug-n-play installation or do I need totally new wiring ?
The law may be different in Denmark but xenon headlights must be accompanied by the automatic self-levelling system and headlight washers.
These are extremely difficult and cost prohibitive to retro-fit. Suspension sensors, new front bumper, larger washer bottle, CANBUS coding etc.
And this is all before you have even bought the actual headlights. Xenon headlights for the Octavia MkII are still expensive and they have been around since 2005. The brand new bi-xenon units for the MkIII with integrated LED DRL's will only be available to buy from a Skoda main dealer and are likely to be very expensive, especially after you have added the ignitors, ballasts and bulbs.
I'd imagine the wiring harness / connectors will be different too.
In comparison the factory order price you mention of £2,000+ will be a much cheaper alternative.
Yeah to retrofit OEM Bi-xenons, cornering and self levelling functions and washer system would cost an absolute fortune, unless you happened to come upon the parts cheap and were competent enough to so the retrofit yourself. If you want the suggest you spec them as comparably the factory option is cheap.
Edited by pipsyp
The headlight washers are only mandatory if the bi-xenons are above a certain wattage - Skoda's must be I guess. There are some cars out there with standard bi-xenons that don't have washers for that reason.
An Elegance without xenons still gets the headlight washers in the UK, is that not the same washer system?
In Denmark the Elegance comes with washers as well - also for the models without xenon.
I would think so Matt - but do Elegance models in other countries have headlight washers as standard?
But I agree that it would not be practical to retrofit the bi-xenons
I can confirm in Romania they don't come as standard
In Norway ALL models have headlight washers as standard.
Edited by Kabe111
Nordic cars need it more... I would think the same about British ones too if you consider the raining percents a year.
Thanks a stack guys.
I thought it would be rather complicated, we should've chipped the last coins in at the dealer  :wall:
According to the law you have to change the lights to have also washer...
I've sent a request to change the order to have manufacturing attached bi-xenons. I simply couldn't this amount of money on a car and not get it exactly as I wanted :)
That is correct. This is already an expensive car and you should spec it according to the needs. I drove in 2012 5h in total during night... so it,s not usefull for me.
I had bi-xenons on my L&K and swore I would never drive a car again without them, however I could not justify the extra £1000 (and 3 month wait) even though I do a lot of driving.
so far I have only used light assist once, but for the roads I alwasy liked bi-xenon on, I actaully think Light assist will help me just as much.
I pick it mainly for the aestethics, I just love that bright white/blueish glow.
Secondly there's the safety and lastly the re-sell value.
You can get the "glow" by using tinted halogen bulbs.
Safety - well badly aligned and fitted HID's are a complete menace on the road - and such a high percentage of the after-market ones fitted are this way. So not exactly safe for any poor sod coming towards you.
As for re-sell - I'd ask for a discount if I found a car for sale that had after-market lights fitted as I'd want them out and things returning to original.
So definitely go for OEM's - cause all 3 of the above are negated :)
Edited by Stoofa
I picked the originals factory fitted to avoid a lot of what you list there. The LED in the OEMs I have seen so far looks ridicously Audi knock-offish.
  • 10 months later...
Will it be that expensive?
The washer is already at the car - at least in the UK an the Nordic.
I guess that the engine for leveling the Xenon light is build into the light - as it is with the regular light
But the front and rear suspension bits so that the car knows if it is pointing up or down aren't
Having washers all the rest is easier.
But still will run you a good cost.
The main price would be the headlights.
  • 3 months later...
What would it take to do it?
  • 1 year later...
I've changed headlight to OE bi-xenon  and tried to adapting it without a malfunction.  I've bought adapter from 9 pin to 7 pin , and I failed to make the lighting stable and always when it work, it`s illuminate and then shut down for more than three time then works...is there any ideas for coding ...?
 My car octavia mk3 2015 and here you are my scan befor installation:
Chassis Type: NE (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBAN2NE5F0133643   Mileage: 25530km-15863miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CWVA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 057 AF    HW: 04E 907 309 AH
   Component: R4 1.6l MPI   H23 9127
   Revision: 31H23000
   Coding: 011A0052032400000000
   Shop #: WSC 23138 002 1048576
   ASAM Dataset: EV_ECM16MPI01104E906057AF 001015
   ROD: EV_ECM16MPI01104E906057AF_SK37.rod
   VCID: 6BDE302A8215D466AE-803E
No fault code found.
Readiness: 1110 0001
Address 02: Auto Trans (J217)       Labels: 09G-927-749.clb
   Part No SW: 09G 927 749 C    HW: 09G 927 749 C
   Component: AISIN AG6 G3  102 2867
   Coding: 010100000C000000000000000000000000000000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_SK25.rod
   VCID: 3972DA62B8C9B6F66C-806C
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 C    HW: 3Q0 907 379 C
   Component: ESC           H32 0384
   Revision: 00000000    Serial number: 63144000000682
   Coding: 1A076A912423216F007D060441C6245856248400608224B200430030C002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 034024
   ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
   VCID: 3A70C56EBDCFBDEE65-806E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5E0 820 047 M    HW: 5E0 820 047 M
   Component: AC Manuell    H04 0907
   Revision: 00001K06
   Coding: 01010004100100000000000000400000
   ASAM Dataset: EV_ACManueBHBVW37X 003017
   ROD: EV_ACManueBHBVW37X_SE37.rod
   VCID: 2C5CF336479B135EE7-8078
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0137
   Serial number: 01011431300192
   Coding: 0C0018424047005B47E04000000407000000000000000000000000000000
   Shop #: WSC 73430 790 12345
   ASAM Dataset: EV_BCMCONTI 013000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7DFA0E72EC614AD600-8028
   Slave 1:
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 141101  041 0570
   Serial number:         141111114947
   Coding: 065DDD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0048
   Revision: --------    Serial number: 39211432500085
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_SK37.rod
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AD    HW: 3Q0 959 655 AD
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P5PQ4C1X5
   Coding: 8800C00000000000400000CC000800000065
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 000477869B93273E6B-8054
   Crash sensor for front airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 801 210 14
   Component: FrontSensor_D  114 0149
   Serial number: 3556VD5D1CE04000000Q
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 DF    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 19111404400905
   Coding: 1410
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_SK37.rod
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 5E0 920 740     HW: 5E0 920 740
   Component: KOMBI         204 4290
   Coding: 07A502082180000801082A001000000000000000
   Shop #: WSC 73430 031 12345
   ASAM Dataset: EV_DashBoardVDDMQBAB 009040
   ROD: EV_DashBoardVDDMQBAB_AU37.rod
   VCID: 60C457067BD3873E0B-8034
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1204
   Revision: --------    Serial number: 0002758308
   Coding: 0101000820086400EF0000081C0F00000001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear.rod
   VCID: 71E22242A0393EB694-8024
   Alternator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000B0270160314
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000126754117
   Coding: 00110120D000040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 448CBB96CF0BFB1E0F-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000004345044
   Coding: 010200
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 R    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB.rod
   VCID: 438EB88ACA05FC2636-8016
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000126628552
   Coding: 00110120DE00040000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000004435261
   Coding: 190200
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5E0 035 840 A    HW: 5E0 035 840 A
   Component: MU-S--ER      041 0435
   Serial number: S3E01811143182
   Coding: 03730100FF00000011110001001100002F0000840100010002
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: 1F4614FA062DF8C672-804A
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H60 0030
   Serial number: SKZ8Z9PT100FQR
End-------------------------(Elapsed Time: 03:23)--------------------------
