sports suspension
heres one
Møller Bil Grorud if you live around Oslo  ;) They have at least one you can go and test drive.
I live In Mandal. Been to Arendal, Kristiansand, Lyngdal. Not a single one
But I get a little concerned about sports suspension after what Neuroteek says here
But you can aslo read above that many people disagree with me, if the roads in Norway are better than in Croatia, where they range from great to bloody awful, it will be ok for you.
What i am 100% sure about, no matter what other people say, mk2 sport on 17" is much more comfortable ride.
I have 18" and sport suspension on the new octy 3. It looks great and the driving feels good. You don´t have to worry about norwegian roads.
Norwegian roads are pretty decent where I live. I know the roadconditions In Croatia!!
Anyway, it looks so much better with sportsuspension!!
Edited by Mort1
But in Norway, one must not drive faster than 70 km / h :hi:
70km/h=43Mph
Edited by Perra79
I've been in both countries and the Norwegian ones are top notch.
The motorways in Croatia are really good though, I was impressed! I wish we had even half of what they have.
  • 9 years later...
Hi folks, does anyone know the dimensions of coil springs for preface octavia 3 estate 2.0 tdi 150 DSG6 FWD with factory sport suspension?
I believe they should be 272mm front and 319mm rear but not sure.
Thanks in advance
Thanks in advance
According the gknautomotive spring catalogue, the Octavia MK3 2.0TDI 184HP VRS manual gearbox uses 5Q0411105HC sports front springs, and the Octavia MK3 2.0TDI 184HP VRS automatic gearbox uses 5Q0411105HD sports front springs. However, the Kilen spring catalogue thinks that the springs are one or two weight ranges higher than this. So it's best to check your car's build codes to find out exactly what springs the car left the factory with.
gknautomotive lists the 5Q0411105HD as having a length of 284mm and a wire diameter of 12.25mm.
Notice in the chart below, that 5Q0411105HD corresponds to build code L17.
If you have a list of all your car's build codes, you can check whether it has build code L17, or some other Lxx number.
Front sports coil springs for Octavia MK3 front wheel drive
1 5Q0411105HC Front sports coil spring
1 paint mark
1 paint mark
green
Grey
  L16
1 5Q0411105HD Front sports coil spring
1 paint mark
1 paint mark
brown
white
  L17
1 5Q0411105HE Front sports coil spring
1 paint mark
1 paint mark
brown
yellow
  L18
1 5Q0411105HF Front sports coil spring
1 paint mark
1 paint mark
brown
orange
  L19
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/4/411/411030
Rear sports coil springs for Octavia MK3 front wheel drive, standard rear axle, ie. not multi-link rear axle (build code 0N1=standard rear axle)
  5Q0511121AK Rear sports coil spring     1JC+0YA
  5Q0511121AL Rear sports coil spring     1JC+0YB
  5Q0511121AM Rear sports coil spring     1JC+0YC
  5Q0511121AN Rear sports coil spring     1JC+0YD
  5Q0511121AP Rear sports coil spring     1JC+0YE
  5Q0511121AQ Rear sports coil spring     1JC+0YF
  5Q0511121AR Rear sports coil spring     1JC+0YG
  5Q0511121AS Rear sports coil spring     1JC+0YH
  5Q0511121AT Rear sports coil spring   2 1JC+0YJ
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/5/511/511000
VW codes decoder
1JA = Rear shock absorption, basic design 1
UC7 = Rear shock absorption, chassis with increased ride height
1JC = Rear shock absorption for sports design
0N1 = Standard rear axle
0N4 = 4-link rear suspension
http://igorweb.org/equidec.aspx
Edited by Carlston
You are correct for front spring being 284mm and pn 5Q0411105HD but this numer also correzponds to eibach spring with length 272mm which is strange.
Apart from that I do not find any info for the numbers for rear end you provided.
Hopefully an owner of such setup joins the thread
1 hour ago, lybrator said:
You are correct for front spring being 284mm and pn 5Q0411105HD but this number also corresponds to eibach spring with length 272mm which is strange.
Eibach R19488 is sold to replace three OEM part numbers, ie. 5Q0411105HD, 5Q0411105GD, and 5Q0411105KE. Therefore, the Eibach R19488 might not be a copy of 5Q0411105HD, but one of the other two OEM part numbers.
If the Eibach R19488 is a copy of 5Q0411105HD, then it's normal for manufacturers to make slightly different lengths from one another. This is because they purchase a spring from VAG to copy, and not surprisingly the springs that VAG sells are not always exactly the same length due to manufacturing tolerances, different factories, different batches, etc.
I once purchased two genuine and supposedly identical OEM springs, but they were about 10mm different in length. They had been manufactured in different years, so they weren't from the same batch, and maybe not even the same factory. The parts guy immediately gave me a full refund and ordered in freshly made parts, that hadn't been sitting around on the shelf for years. The freshly ordered in parts were an identical pair.
  5Q0511121AT Rear sports coil spring     1JC+0YJ
Eibach R18898 is sold to replace 5Q0511121AM.
Eibach R17249 is sold to replace 5Q0511121AN and 5Q0511121AP.
Eibach R17744 is sold to replace 5Q0511121AQ and 5Q0511121AR.
Monroe SP4175 is sold to replace 5Q0511121AM and 5Q0511121AN.
Edited by Carlston
