Amp Advice
Hi looking for some ideas as to which 4ch amp to get. I'm looking to get Hertz DSK 165.3 & 130.3, read up seems to be coming in the best to replace the stock speakers unless you have any other suggestions for speakers. I use the boot fair bit to chuck everything in including the dog, so plan is to house the amp in with spare wheel if can get one small enough
Jl audio xd amps are like 10"x7
I have a xd400/4 and xd600/1
Both are under the floor
Speakerwise.... Depends on budget :)
Focal do some shallow mount ones
I have jl c5s and i cant rate them enough
Amps look good.
What sub you running xd600/1?
Jl c5's lil pricey for this car myt look at them for my mk2 tho thanks. Budget for speakers probably bout £300 for front and rears :sweat:
I have 8w3v3s :)
Jl c2s are around £120 a set :) iirc
Another vote for jl audio amplifiers. They are top notch.
Genesis Dual Mono
British hand-built amp
I have one these - runs my 2ohm fronts components
Power cap ? Lloyd imo why do you have such poo ?
I added 5 farad cap. result bass much deeper tighter less boomy.
why do you think one of my hi fi amps has 40,000mf of power supply capacitance.
the higher farad in a car is due to lower voltage.
Hey lol :drunk:
My power caps been with me ages , it was a huge help when had earlier installs with twin 15s and other big power amps :rock:
It made light dimming less..... ish
Certainly does no harm :angel:
Plus he must me close to retirement :giggle:
I had the first power cap in Cardiff.
That was nearly 20 years ago lol
Ears have never been the same after around 133 db
Pardon did somebody say something. ..
Sent from my GT-I9300 using Tapatalk 2
WHAT THAT DAVE ??
Oh i dont have to type loud as you'll be reading this :D
"He's deaf.. Not STU-PID"
Short of a secondary, isolated battery (charge only - no engine drain), they can be a useful addition. Many however, leave a lot to be desired...
Its a nice stinger from....
Sometime in my younger years lol
However, old caps aren't so likely to be great. Big aluminium electrolytics tend to go a bit crappy over time. They certainly have a finite life.
He is fine :)
Mustve had a few hours use lol
Either way all sounds nice and is in its home
For now until i change it randomly :D
i've never been a fan of capacitors myself for bigger installations, i prefer to use a uprated alternator and/or a split charging system.. but to be fair there is more than one way to skin a cat as they say..
i'm certain my hearing is starting to fail, i work with large pa systems and various sound stuff for massive outdoor events/theatre/festivals etc and i'm sure the sound pressure levels ive been exposed to has damaged my hearing
I do have a yummy alternator too
I did the 90's in various fields clubs and my car.
If theres much background noise I can hardly hear these days.
I paid about 250 for the power cap. I think they had just come out for car audio. Iirc it was a monster cap. I bet they are about tuppence hapenny these days
What type of battery you using ?
Who me ???
Sorry, that was Lloyd
I use to use the optima yellow tops
Cant be arsed now live scaled down bit by bit
More n more
Id like to end with a tidy 5 channel
Easy
Neat
Tidy
Front n rears and a single sub
I somehow always end up with 3 amps
Not planned, just seems to happen
