AP coilovers more problems from GNJ motorsports HELP
My mate is fitting them and said
Number 1,
theres no lockers on the rear adjusters, there should be a tapped hole with a grub screw they are slack and will just vibrate to lowest setting
Number 2,
thinks there should have the clips for the abs sensor cable and the lockers on the rear spring cups.
Have I got a bad batch and is the above 2 comments true?
