I'm beaten, superb dash fuse box.
I'm trying to find the plastic clip located in the fuse cover as stated in the manual. It's not in the engine comp't cover so presume its in the dash fuse box located at one end of the dashboard either 'to the left' as shown in the manual but picture is of a left hand drive superb or on the right next to my steering wheel. Thing is, I can't find the 'screw' to release the fuse safety cover as described. I've searched our forum for location info but nowt down for pal.
So can anyone advise where the damn fuse box is and how do I get to it.
2009 (2010 MY) Superb Elegance, 170CR DSG Twindoor
So it is the fuse.box you are trying to find?
Open driver door, behind panel on side of dash, should just priseoff with flat screwdriver or something
Thanks Coops. Gave me confidence to prise pull yank and pull back rubber trim with my third hand.
Sorted, cheers but no fuse remover thingy but at least I know for the future.
No need for a screwdriver, the car key is a perfect shape to fit.
The 'fuse remover thingy' is a small white plastic pair of what can only be described as tweezers, which should be attached to the back of the cover you removed (if not previously lost)
Thanks folks, sorted now, miniature pliers for the fuse and a wrecking bar for the cover ....,...
