Help installing a parrot mki9200 into an octavia
How did you fit the usb lead in the bottom glove did you have to drill a hole? And when I piggy back the fuse which fuse is best to go off ?
By the way cheers for the uploads
DMilleaVRS
Edited by DMilleaVRS
  • Replies 51
  • Views 8.6k
  • Well after 3 hours, job well done finally got it in, hardest part was trying to get all the wires positioned so the unit would slip back in but overall impressed with bit of kit and all for £102
  • Ive got a rook of pics of tge install what I used and what I removed could put um up or email them if any one needs them DMilleaVRS
  • bulls20042002
    bulls20042002
    At last finally got them to upload, God only knows why there on there side I split the lead with the inputs ,and ran one up to my phone holder so I can charge my phone, The other runs to the box do
My next question would be how do ypu change the background picture?
DMilleaVRS
Mine is connected to the wiper fuse,
You don't have to drill any holes,
As the small glove box has no lid so its just drops in,
All i had to do was split the 3 input cables,
Because i wanted them going to different locations,
Ive attached a screen short from a PDF on how to change the background,
Hope it helps
http://www.parrot.com/documents/texte/image/2mki9200---user-guide-en.pdf
Cheers buddy
DMilleaVRS
Only gone and ordered the wrong piggy back fuse bought a normal 10amp fuse one is there a normal size fuse in there I can use or do I defo need the mini
DMilleaVRS
Attempting to fit my parrot kit today wish me luck
DMilleaVRS
You'll be fine mate, it's a good way to learn about your car
Cheers mate
Think I've got everything might have to buy a new piggy back fuse though unless I can get away with the large one
DMilleaVRS
Cheers mate
DMilleaVRS
You could wire the rest if it doesn't fit and then add the piggy back fuse at the end. I know it's a pain and you can't test it, but at least the easiest bit would be the only thing left
Very true I only live 10 mims from maplins so might just have a run up there if needs be.
DMilleaVRS
Before I pull this bolero out I cannot find any where about the code for it obviously if I disconnect it it will need the security code inputted but I dont have a clue where it is, it states in the manual that its equipped with a convenience coding says the codes stored in the instrument cluster and manual code is normally not necessary...what does it mean by that. ...sorry to sound lame
DMilleaVRS
No you don't need a code if it came with the car.
Sent from my Nexus 4 using Tapatalk 4
Things is I was never given or told a code or told I needed one I dodnt buy the car from a skoda dealers so how would I know of it has come with a code?
DMilleaVRS
So if it is the original bolero and all im doing is putting it back in it shouldn't need a code?
DMilleaVRS
Right got it all weird up but only got three speakers working my drivers one has no sound.....any clues y I think it might have summit to do with the mute lead?
DMilleaVRS
Check the connections, I had no sound from the back to start with as I hadn't pushed one the connections in properly.
Like to thank everyone who helped me with information thank you.
DMilleaVRS
Top man well done!
DMilleaVRS
Well done mate!
Hi, I notice according to the fitting instructions that the kit comes with a mute wire - is there a mute connection on the HU/harness for the Octy? Thanks in advance.
Redjay: What headunit have you got?
I've got a 'swing radio' on a 12 plate - base model no volume control on stalk or aux etc. From what I can gather the radio is a rebadged RCD 310 made by delphi.
Cheers
In that case:
http://www.my-gti.com/1319/volkswagen-rcd-310-pin-assignments
(connector 4, pin 10)
I had (still have in a box) an RCD 310 with a Nokia car kit in and it worked ok. Also wired the car kit output to the input so the sound came from the h/u (no need to fine a space for the speaker ;) )
You'll need the connector and some repair wires to make the install easy (No more than a tenner from a dealer). I honestly can't remember whether it's the blue connector or the green one you'd need.
Thanks Rainbowfire. I've ordered an SOT cable for the ISO and quadlock harnesses, and a piggyback mircofuse for the switched power. Hopefully all the kit will be here for Saturday and I can have a day that is relatively frustration free...
