LED number plate lights standard?
might try tps and see how much they are.  so the 1K8943021C oem numberplate lights will be plug and play with no bulb out errors
They will give bulb out errors without coding. Mine cost 68€.
Too Tall,
These LED lights wont work with the Octavia 3 are the Superb 2 facelift as the connections are different. I have just found this out when I went to swap my lights from the pre-facelift to the new facelift with modification
Only just seen this, I believe they are on the Golf GTD and are different the octavia 3 i could be wrong but
Should do yes, i have the resistors in place and it has cancelled mine
Hi
so when you are coding this error out, there are two bits to check - byte 17 in the long coding helper for central electrics lets you turn off the pulse modulation check so you can use LEDs (all that i have done on mine) and you can also disable cold check a few bits further along the coding string.
t.
Edited by tmg
