HELP ! superb not responding to ignition
Seeking advice from BRISKODA comunity ....
-my skoda superb's not starting to ignition.
-the display's telling me to move the automatic lever to P/N when its actually parked.
-a mechanic came by and jumpstarted it directly.
- drove the car down to dealership and then at the service station they told me it was a problem with the ignition switch and it was promptly replaced.
- the car was starting normally after for like 2 days and now the problem is back !!
- the saga - i sit in my car and then turn on the ignition with the key and the display shows the same message.
- i call up the dealer and he says he needs to check it once again - but service station for me is a 3 hour drive !
so need your opinions so that i can discuss with the technician above the problem . . help much appreciated !
Seeking advice from BRISKODA comunity ....-my skoda superb's not starting to ignition. -the display's telling me to move the automatic lever to P/N when its actually parked.-a mechanic came by and jumpstarted it directly.- drove the car down to dealership and then at the service station they told me it was a problem with the ignition switch and it was promptly replaced.- the car was starting normally after for like 2 days and now the problem is back !!- the saga - i sit in my car and then turn on the ignition with the key and the display shows the same message.- i call up the dealer and he says he needs to check it once again - but service station for me is a 3 hour drive !so need your opinions so that i can discuss with the technician above the problem . . help much appreciated !
