Installed new Columbus stereo, vcds says cannot connect to ecu can anyone help please
I  have just installed a new Columbus in 2010 vrs. The columbus works perfectly apart from voice.
But when I try to connect to it via vcds using 56 radio or 37 nav it says there is a problem with the ecu and wont load the long code helper.
Have looked on ross tech wiki but still do not see why it can't connect. this is the fault code from can gateway.
Any ideas please ?
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K10407081D
   Coding: E9A07F06400602002303
   Shop #: WSC 73430 790 00999
   VCID: 69D2C8AB40475F50975
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 230
                    Mileage: 52643 km
                    Time Indication: 0
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 230
                    Mileage: 52644 km
                    Time Indication: 0
any other faults?
does the radio switch off when you pull the key out?
Radio switches off and all functions work apart from voice. Another thread says on early cars sound not available. Not too fussed about sound. I have enabled 37 and navigation all perfect and on maxi dot too.
Full scan here
Sunday,08,September,2013,16:13:15:16061
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: TMBUF21Z4A2115070
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 1Z0 907 115 AF HW: 1Z0 907 115 F
Component: 2.0l R4/4V TFSI 0010
Revision: AAH16--- Serial number:
Coding: 0203000C18070160
Shop #: WSC 01286 386 08256
VCID: 79F298EB30E7EFD0675
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 163B601C092300FF680B06EB90190081340800
VCID: 78F49DEFCBEDF6D818B
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_SK35.rod
VCID: 830E7A030A2B2500BD9
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 4E180AB8B849B1C040080080010081E4430100AE424D8D60800540040000
VCID: 32606FC76D11DC88E6F
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 24031 22 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Subsystem 3 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
1 Fault Found:
03266 - Control Circuit for Signal Horn
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 175
Mileage: 52148 km
Time Indication: 0
Date: 2102.14.17
Time: 20:35:06
Freeze Frame:
Term 15 On
Voltage: 11.90 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 C HW: 1Z0 919 475 A
Component: PARKHILFE 8K H06 0006
Revision: -------- Serial number: 66541007403585
Coding: 100002
VCID: 4182300BD8B777106F5
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2KZ0R4
Coding: 0020788
VCID: 3D7A4CFB644F13F00BD
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0000832
Shop #: WSC 12345 123 12345
VCID: 76E893D701F980A80A7
Subsystem 1 - Part No: 3T0 959 537 A Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0011
Coding: 00000131
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 943 H HW: 1Z0 920 943 H
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 710B00
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3E784BF7A14908E8127
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 230
Mileage: 52643 km
Time Indication: 0
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 230
Mileage: 52644 km
Time Indication: 0
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EAD037A70D41D4481EF
Address 37: Navigation (J0506) Labels: None
Part No SW: 3T0 035 686 C HW: 3T0 035 686 C
Component: RNS-MID H09 5238
Revision: AB001001 Serial number: SKZ6Z7N5133122
Coding: 04000402000400810000
Shop #: WSC 33361 790 00085
ASAM Dataset: ------------------------- ------
VCID: 366853D78179C0A8CA7
Subsystem 1 - Part No: 3T0 051 859 M
Component: EU West V9 7918
2 Faults Found:
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 190
Mileage: 52645 km
Time Indication: 0
Date: 2102.14.27
Time: 16:10:29
02877 - Digital Radio Antenna (R183)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 190
Mileage: 52640 km
Time Indication: 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2114
Coding: 0000756
VCID: 48942D2F3B8D4658A8B
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 316260CBA817E7909F5
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 47962E1336934920A11
Address 56: Radio (J0506) Labels: None
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 190
Mileage: 52640 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 190
Mileage: 52645 km
Time Indication: 0
Date: 2102.14.27
Time: 16:10:29
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012551
VCID: 32606FC7AD11DC88E6F
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 336E6AC3520BD580ED9
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 C HW: 3C8 035 730 C
Component: Telefon 012 0822
Revision: -------- Serial number: 35909603527251
Coding: 020000010100010000000000
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_SK35.rod
VCID: 234E9A832AEB45001D9
2 Faults Found:
9457427 - Negative output audio channel for speech/telephone
B104F 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 230
Mileage: 52643 km
Date: 2038.14.26
Time: 19:24:17
9457171 - Positive output audio channel for speech/telephone
B104E 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 230
Mileage: 52643 km
Date: 2038.14.26
Time: 19:24:17
End
  • 5 months later...
Thanks Mike
Sadly I cant even get into the coding for 37/56 as the Columbus is not recognised. In my case it is because a software update failed at the gateway update stage. So what I am hoping for is to find a way to get the Columbus recognised by the CAN gateway so I can possibly adjust the clock setting which is currently stopping me updating the software.
However, looking at the gateway coding, its only an installation list and 37/56 are ticked so not sure VCDS can help on this one.
Adam
I can't until I change the clock setting as the swl discs won't take. And unfortunately as without the gateway communicating with the Columbus I can't change the clock!!
Adam, isn't the clock independent from the Columbus and changed through the maxidot? I think I remember somewhere that it had to be changed from 12 hour clock to 24 hour version or vice versa.
Ian
That is exactly correct Ian but because the gateway doesn't recognise the HU it doesn't seem to be being changed as far the HU goes, even when I change it in the maxidot...
  • 2 years later...
HI! Did you get to the bottom of this? I have a RNS510 1T0...BX with the same issue, it just won't connect/communicate with the CAN. I installed fw5238. I put it on 2 different cars, VCDS can't read it and Test mode shows no communication with CAN. I think it's a hardware issue, but which one and is there anything to be done? Thanks
CAN Gateway errors are:
and
01304 - Radio
I resolved in the end by having the firmware reflashed to the Columbus outside the car. I used a company called hazzydayz.
Edited by adamal
Just finished reassembling the unit, it works great.
