Potential twindoor problem
Hi all, Have noticed lately when using my twindoor in hatch mode it opens as it should but when closing it I can hear the main hatch catch pull in and close ( if I listen carefully i can even hear the mico switch click) but now there is about a 3 second delay to the side locks powering in, Im fairly sure this used to happen almost as soon as the main hatch had pulled in and locked! Has anyone else experienced this could it been a potential problem starting? Cheers all
Hi.
I don't understand exactly, explain me please, what did happened when blinked two times the 3th brake light, what button you pushed etc.
Sometimes if I using my twindoor in hatch mode, the 3th brake light blinked two times for signalling ready to open with the button.
If I push the button, need immediately pull up the door, else it will remain locked. in this case can't open it, need to push down, for locking it and repeat it again.
If I push the button and pull it up immediately, it will open, as we expected.
