Clutchproblems....
After 500 chiped-miles, the original clutch is already starting to slip under acceleration. Can anyone recommend a better clutch for the RS? Is the clutch for the Audi TT 225hk more powerful?
/Kribban
Whose chip do you use as it must put out a lot more torque than my superchips (circa 210lbf.ft) where the clutch is fine after +7k?
As long as the clutch is fuly engaged before applying turbo I dont see why you have a problem. Are you are tracking or drag-starting the car?
/Kribban[/quote:cbb45f0f07]
The chip (BSR in Sweden) is specified to deliver about 238lbf.ft and 215bhp. The clutch is getting worse now, it slips even under normal acceleration on second gear :cry:
I need a clutch with more reliability than the original obviously. Any advise of a better brand?
Can't advise, sorry.
I had a new clutch put in mine as I felt it was on the way out. My car has been chipped since 10,000 miles. Clutch replaced at 52,000 miles. Of the 42,000 chipped miles, 4,700 were done on a track, so I felt the clutch had lasted fairly well, especially when you consider that they estimate that every mile on track is the equivalent of between 10-15 road miles. Based on that I put in a standard clutch.
Really strange. Maybe I just have bad luck with mine :cry:
