polybush top mounts
and really 'PULL through' shouldnt happen, surely it would be push through. upside down top caps is the only reason they would pull through.
The strut mounting hole is the same size so basically if a 1.9 tdi/sdi polo has 2 heavy guys in the front they will fail there too.
  • 1 year later...
  • Replies 101
  • Views 16.6k
  • Not sure if this helps or not, but I fitted my powerflex top mount bushes this morning. They fit the coilover perfectly, but as others have reported, they seem a little deeper than the stock ones. I h
  • update. I took the polybush top mounts out today replaced with standard Octavia ones. I used the same top bearings that I used with the poly mounts NO CREAKING. So it WAS the mounts making all the noi
  • Up date on this thread folks,   Well fitted the Poly bush top mounts and kept the VRS top plates and 3 days of running and i have to say no issue. The drive is a little better for me because i benef
Have fixed the new top shocker bush mount in my skoda rapid,I am worried because top mount cup plate sit little high, which is annoying me..
you can guide me is this really a serious problem, causing improper brakes etc..
