Indicator problem
My left indicator turns on when I activate my high beams and won't turn off, as a result I can't use my high beam, head light are completely standard, help please!!!!!!
Sent from my C6603 using Tapatalk 2
Does the opposite happen when you turn your left indicator on?
Yes! When I turn on the left indicator the right one comes on! But when I flash the high beams it's fine, I'm baffled!
Try spraying some electrical contact cleaner into the stalk mechanism.
Will do cheers chissey
Update: tried electrical contact cleaner spray seems to have had no effect, anyone have any ideas on where to go from here?
Could you have a bad earth? Next step might be to dismantle the stalks and inspect the wiring.
I had a similar problem sometime ago, opened the stalk housing, cleaned the contacts and the problem was sorted. Now, after a year, it is back intermittently, time to clean them again.
BTW, I doubt a mere spray is going to help at all as there usually is carbon deposit on the contacts and requires "scraping" it off.
Thanks for the replies guys.
hell666 in your experience how easy/hard is it to dismantle the stalk housing? Was looking at it with this in mind but can't find screw holes etc.
I have an indicator stalk from a 56' Octy vRS which works fine if you wanted...
Woo7dy is it the stalk that's definitely the problem? I wanna try cleaning the contacts first, if I get no joy them I'll pm you cheers
Very simple, hope this link helps on how-to
Thanks hell666 I'll give it a bash!
Ok so I've followed the how to guide and cleaned the cruise control assembly, no joy, the problem persists, the problem seems to be where the stalk meets the steering colum, how do I strip that down, I'm certain it's a bad contact in there somewhere
Sent from my C6603 using Tapatalk now Free
You will have to remove the
Airbag
Steering wheel
Steering column trim
Slip ring / Slip ring & control module depending on Model year
Stalk
Remember to disconnect the battery first!!!!
Sent from my Nexus 4 using Tapatalk 4
Airbag
Steering wheel
Stalk
I don't think i'm technically minded enough to tackle this so i'm just going back to the garage that sold me the car (I've only had it a month anyway) He can sort it, Thanks for all the help /  insight guys.
Edited by KeithbagVRS
Have you checked the headlight connector is secure? I had funny problems with lights when I hadn't plugged it properly.
Might try that Nathanio thanks
My mk2 developed a problem where if I indicated right the left one would flash ! As I drive a taxi , I managed a week without using right turn indicator . Now replaced stalk , cost me 36 for new stalk with cruise & 30 to fit . Steering wheel , airbag etc etc all had to come out . Fine now :-)
I've bitten the bullet and purchased a new stalk €50 seems reasonable to put an end to this hassle, I got the car plugged in and the stalk switch is sending the wrong signal to the body control module so it's definitely the stalk causing the problem, I've a guy to fit it as a nixer lined up
  • 4 weeks later...
Update: Got new stalk fitted but the problem is still there! Any idea how much a new body control module costs? And where is it in the car?
Are you still getting faults logged?
There doesn't seem to be a fault, the car was plugged in and the bcm was gettin a signal to activate the near side indicator when the high beams were activated
