Creaking noise like an old bed
HI!
I just replaced the steering rack due to massive leaking and now I'm getting a nasty creaking noise,the car feels like an old bed.Steering,breaking,when starting in 1st gear creaking is allways the same
With the new rack I put new wishbone bushes.
Any ideas?
Top mounts are fine,ARB bushes looks fine,tie rods and end rods were replaced months ago.
What else?
I'm so tired ,it took me 6 hours for the rack replacement,with brushing every bolt from rust....so now my mind is not in the best shape
I tight up the wishbone front bolt with the car on the ground
I had this after a local garage replaced the cam belt and water pump.
They spilled a load of coolant into the lower arms and bushes, which caused horrendous eternal 'old bed' style creaking.
I was able to get rid of it temporarily by spraying a load of WD40 into the rubber bushes - but the only permanent resolution in the end was replacement.
Sounds like the same thing i had, turns out it was the drop links.
No guys,is a bad rack.
I was fitted a bad steering rack.
