Coilovers
I am going for a set of coilovers! Do they make a huge difference to handling? I will prob drop it 30mm
Oh yes :D . I have KW3's on my RS , first thing i noticed is it gripped better in low gears, floor first and the nose would lift, upsetting the balance of the car....wheelspin & steering all over the place....Not anymore,
on a recent trackday the car cornered much flatter and gave better feedback .
Steve
spin all over the place....Not anymore' date='
[/quote']
:thumbup: :sofahide: Sorry. :o Fosters makes you do awful things.
But on a serious note I noticed coilovers on my Fabia DID have a positive effect on the handling under hard acceleration. A feeling of being better "planted" with no suspension jerkiness / wobbliness at all. :) Same applies for cornering - no lifting up of the tyre putting in less cornering effort, etc. Literally felt like being on rails. So I concur with Steve on those points.
I would say go a little lower than 30mm though. Having said that, with the vRS Octy being quite low first off, its probably spot on. :cool:
But on a serious note I noticed coilovers on my Fabia DID have a positive effect on the handling under hard acceleration. A feeling of being better "planted" with no suspension jerkiness / wobbliness at all. :) Same applies for cornering - no lifting up of the tyre putting in less cornering effort' date=' etc. Literally felt like being on rails. So I concur with Steve on those points.
I would say go a little lower than 30mm though. Having said that, with the vRS Octy being quite low first off, its probably spot on. :cool:[/quote']
So there you have it....................Less Spin and NO ROLL. :D:rofl:
Steve
So where's the best place for good deals on KW stuff. Anyone know??
I bought mine secondhand off of Jon but iirc Jabba sell them , check KW's site they must have a dealer link,
Steve
Steve
Touche! :D:thumbup:
Thanks, thats made my mind up now for defo. :thumbup:
  • Administrators
I've personally feel that the ARBs have improved handling more than my last set of coilovers did, but different car (4x4 v VRS). You have the rear ARB so go for it, pick wisely they could if not set up right destroy your handling.
That said if I do much more it needs a set of coilovers, but too much and I loose compliance and stability in cornering on uneven surfaces (aka British Roads) :D
Options are KW, FK and Bilstein(rumours) or H&R
Personally I'm looking to H&R or Bil's.
