Got smelly climate control?
Well you need to get some Comma Air Conditioning Cleaner....by accident found this in my local Halfrauds....works wells...costs approx
Ah :D Finally someone who responds to where to buy it from ;)
The product was mentioned elsewhere but didnt get a response on where to get it from at the time.
Halfrauds it is, just hope the small one in A'don sells it :D
Cheers Adrian :thumbup:
Sorry. I thought I said I got mine from Halfords. :o
Adrian is right though. To be on the safe side buy two.
Just used one tin on mine today, seems to have worked OK. :thumbup:
Saying that I don't think my CC was that bad as it only seemed to smell for a few seconds after start up.
Yup it's good, I used it a bit ago and was well impressed.
Yeh I was impressed to begin with then about 2 weeks later the smell is back.
Im not sure what causes the smell, could it be a damp pollen filter? through which all external air is being drawn, cos there is no smell in re-circ
Im not sure what causes the smell' date=' could it be a damp pollen filter? through which all external air is being drawn, cos there is no smell in re-circ[/quote']
Could be bacteria build up in the system. do you go long periods without using the AC? The system should be used a little even in the winter, just to keep bacteria at bay.
Once bacteria takes hold its quite difficult to get rid of. Might need to visit the dealer to have the system cleaned, but this is not always 100%.
Always have mine on and it still does it :(
I use Fortron treatment which works in the same way (switch a/c onto recirc, close all windows and doors, set the can off under the recirc intake and get out, leave for 5 mins, remove the now empty can, then leave ac for a further 5 mins.)
Works a treat.
Lummox: Is it hard to manually clean the part of the system that collects whatever sunk there is that smells? I suppose it could be a dash-dismantling exercise?
Yep, same here, mine is used every day
Yeah ends up like this on a Fabia...
The treatments work well.
I use Fortron treatment which works in the same way (switch a/c onto recirc' date=' close all windows and doors, set the can off under the recirc intake and get out, leave for 5 mins, remove the now empty can, then leave ac for a further 5 mins.)
Works a treat.[/quote']
where from then ?
i get a smell if i switch from AUTO to ECON on the climatronic... is this the same thing?
the smell doesnt last forever mind, about 5 minutes.
got the Comma one from Halfords at the weekend. ended up getting a few other bits and bobs as well (total spendage =
Just noticed this on the A1 motor shops site. They are selling the Comma aircon cleaner with
I'm NOT going to get one of those aerosols if it does this to the dashboard !! LOL LOL LOL
one thing that did annoy me was the film the spray left on the centre console and windscreen !
Yes, why is that? I have a Fabia and I put the aerosol on the rear floor. The console was drenched with moisture, but not the dashboard, door panels or anywhere else. It does a good job though.
Didn't have anything on dash/seat after doing mine....although I was prepared for some...it says there might be some moisture in the instructions.
basically i should have expected it as the instructions tell you to put the climate on full whack with recirc and windscreen.
the vapours are pulled through the aircon unit and blown out over the windscreen.
the film and wetness on the centre console and hand brake surround is simply from the spray being pulled towards the dash by the air moving around the cabin.
The guys who fix our office aircon just recommend Dettox or similar. Fan on full, and give it a few squirts into the intakes.
You might want to leave the windows open though!
Phil
I prefer to "burn" the smell away with full use of the aircon, and always turning the aircon off 5 mins before stopping to allow the system to dry out.
Always works for me.
