Bilstein B12's fitted
Fitted them yesterday and my god what a nightmare the fronts are to do, I could change suspension on a mk2/3 golf in about an hour, but these were on a different level to do.
But all done so happy about that, the feel of the car is totally transformed as it just soooooo nice to drive, feels OE but firmer and its a nice firm ride not harsh at all with so much less body roll, im driving around looking for bends and roundabouts lol.
My only slight concern is that its not as low as I thought it would be?? I was expecting about a 20mm drop but its about the same as when the standard suspension was fitted, will the suspension drop much with more miles??
karl
  • Replies 50
  • Views 7.9k
  • On the DPM Performance website, it states the B12 kit gives a 30mm drop. The Vrs sits around 20mm lower than the standard octavia, so you can only expect a 10mm drop. But it'll take a few miles/weeks
  • We'll go way off-topic with this one, and will only drag the discussion off in a different direction.    With modifications, the expectation always is from the insurers side that you have fitted par
  • If you've got the wrong springs, for a lighter vehicle, then it's going to dive more heavily under breaking and acceleration. The springs could fail due to the extra load.   For the cost of fitting
On the DPM Performance website, it states the B12 kit gives a 30mm drop. The Vrs sits around 20mm lower than the standard octavia, so you can only expect a 10mm drop. But it'll take a few miles/weeks to settle to that.
The front struts can be done with out taking out the driveshaft which is probably a easier to do but it is trickier compare to a golf mk3. The hardest bit is probably getting the strut out of the hub as you need a spreader tool to open up the hub
I swapped my springs from the B12 kit for H&R 35mm drop ones and it sits alot better and grips like mad, I would get a full geometry check done to get the full effect, I had mine done at ABC in Leeds http://www.abc-carservice.co.uk/ it only cost about £115 and it took them nearly 3 hours with two guys.
You got a pic of yours please mate
Don't seem to be able to add the pic for you. What are those wheels? Squared?
Yep Squared SC1 18", got them up for sale but might keep, as they do mean as Fook :devil:
Don't understand sorry
Don't worry, I have Dyslexia and that made sense to me :giggle: , "They look mean as....."
Glad you're liking the b12's karl- agree the drop isn't much.. that's why i went for coilovers.
Good job mate, this will be my next mod when I can get a kit for a tidy price, someone beat me to this one lol!
Just won me a new Bilstein B12 kit and I'm well happy, not quite as cheap as you (kadvr6) at £181 but £231 is still a bargain nonetheless, happy days coz I won by 9p lol!
Edited by billywhiz040480
Hi billy you are aware that the kit you won is for Axel weight up to 1020 not from 1021kg your kit comes with different springs.
Sent from my Nexus 7 using Tapatalk 2
Oh dear I didn't realise that, I thought it was too good to be true, they were advertised for a Skoda Octavia mk2 1z 55mm so I assumed they were perfect, what would have happen if I'd fitted them had you not said?
I don't know you might just end up with a little more drop them Karl ??
Sent from my Nexus 4 using Tapatalk
I've just messaged the seller now to confirm what you just said as it does say in the listing that the dampers are fine but it doesn't say about the springs. Looks like I've not had that great a deal after all, because if the springs are no good I'll have to splash out on a set of Eibach pro springs, oh well.
Just fit and see as it may be fine as the back end may be slightly lower due to heavier back end, however u still have a bargin as shocks alone for b8s are around £500
Well done mate. Think all that will happen is maybe the front will sit lower than mine. But you will enjoy them when they are fitted. I am.
How much drop am I looking at, it says 30mm front and back on the listing?
Well thats 30mm if it was not a vrs. So like mine it will be about a 15mm drop unless you get some 50mm h&r springs. Which will lower it about 35mm.
If the springs supplied with the kit you've won are not rated correctly for your axle loadings, then you might find that the body control and general handling and comfort isn't as good as it could be. Depends how far it's off.
You'll see your axle weights when you open the passenger door, on the door jamb.
You are also potentially giving your insurers an out if you are ever involved in an accident, as the springs are rated for a lighter vehicle configuration.
And before any say how will they know, if a vehicle inspection is carried out and they check the part numbers on the springs, they would be able to see that they are incorrectly rated.
sorry but as long as you tell the insurance its lowered its covered, no insurance company assessor will be checking part numbers of springs.
With modifications, the expectation always is from the insurers side that you have fitted parts that are fully compatible with the vehicle you're fitting them to and are suitable for the intended application. Fitting springs with the wrong axle loading do not fit into that category unfortunately.
Whether that would ever be discovered in the event of an incident depends entirely on any investigation that took place, and how hard they were looking. In the event of a fatality, for example.
