Progress on the Fabia project
Thought I'd give a little summary of progress so far and hurdles yet to overcome.
In the word's of Jason Vs RunDMC - It goes a little something like this:
Ripped PD100 out of Fabia, along with SMIC
Inserted PD130 with salvaged outer hubs - Beforehand, opening up to fit in JBS 400 lb/ft clutch. :cool: Can't wait to run it in. :D
Camber was miles out, so renewed both (crash damaged :mad: ) outer hubs, renewed both consoles, and the subframe. This sorted out camber issues.
PD100 gear cables (5 speed) wouldn't attach to six speed gearbox lever (all was reversed or something) so six speed box fitted with vRS gearknob too.
FMIC is bolted to bumper mounting bar, chopped out bits where fitting an issue and to improve airflow.
Problem with Allard pipework not fitting pd130 inlet overcome by using OEM bend, and chopped off bracket and attached to metal pipework
Still need to resolve that inlet & outlet of hybrid turbo is bigger than pipework going to it. :D
Found PD130 engine harness didn't hook up with PD100 compartment loom - PD130 compartment loom on the way - hoping it matches up fine with other engine bay components like foglights, etc.
vRS dashpod went in easy though. :thumbup:
Bodywork sorted - rust has been cut out and arch reformed - looks very good - also sorted out gap in rear bumper & flushed the boot badge area too. Also sorted out front bumper that I hacked about with a stanley knife to remove numberplate area. Getting motorcycle style plate for new private plate. ;) Reckon it will fit nicely between front left fog & the new "mouth" - Ripspeed :o mesh used in the "mouth" to protect FMIC from large missiles.
Hybrid turbo is still to go on the block but there's the pipework issue to sort out too. Also got new pair of hub nuts on the way too - hopefully the last new bits I'll need from Skoda themselves. :)
Ahem, can't think of much more I've still got to do. The loom is the BIG job next, then it'll be the small matter of reprogramming the keys and I'll be well away I hope. Oh, and need to put some oil in the block & gearbox. :D
Onwards and upwards. :thumbup:
Forgot to mention, I'll be back to Jabba mid August now, after rebooking to allow for time to be spent on works. :cool:
sounding a bit more positive now :thumbup:
Dare we ask the price so far? :D
You may but I ain't telling ;) :P. At the moment I'd say if I'd got what my car is worth - say roughly
Give you a tenner for your old PD100? :D
Apart from the keys & loom, etc, is there likely to be any more stumbling blocks?
Apart from the keys & loom' date=' etc, is there likely to be any more stumbling blocks?[/quote']
I f***ing well hope not! :rofl::thumbup:
I can't honestly think of ANY further possible stumbling blocks, but one or two are bound to surface. :rolleyes: Only thing I can see if breaking something in the removal / refit of the loom, but after Ross' kind words I think its not as hard as it sounds - There can't be that many electrical appliances under the bonnet, plus I'll have ETKA type thing as backup to ensure what each plug attaches to before attaching. ;)
Edit: I think to get yours converted to diesel you'd need a lot more than just anything I can provide.. fuel tank and fuel pump for one. ;)
Good to see Jason. Looking forward to seeing the finished car.
is certainly sounding a lot more positive :)
hope it all goes from now on mate, will be a little bit of a sleeper when done as it will look like a normal fabia with some stuff to make it look a little bit better bit pack quite a punch :thumbup:
Glad you got a game plan.
Im kinda feeling the same. My pick up is in pieces with alot of new parts to go on before we can even start the prep work for the paint. Its helpfull to have a plan and just work through one item at a time. I seem to be getting one item done a night at the moment.
Good luck mate.
Good luck mate.
Good luck coming from you... hmmm. :( :rofl:
Don't be surprised if you get a phone call saying "where the f*** does this go?" ;)
Keep at it J. You'll get there in the end. Although where that is I'm not quite sure....
Allways here to help mate if I can.
Oh I forgot about one other thing. It would appear the exhaust manifold / exit thingy is in a slightly lower position, which has had the effect of forcing up the tailpipe end of the exhaust against the bumper on the vRS rear end... :rofl: Some exhaust bracket BUTCHERING will be required to lower it again to its normal position, although I'm starting to think a nice big oval tailpipe would be nicer in the vRS "exhaust gap cutout" than the double one hanging down below it, looking a little oversized.
Thanks for all the good wishes. After a long time its all starting to come together... However I never envisaged a 6 week build when I first started.... :rofl:
What about a twin exit J, not seen one before.
You mean splitting it half way under the car? Would be nice but a lot of work given the channel cut out for the OEM position of the exhaust. Also would look a little odd unless I could get a mirror vRS style cutout on the other side of the back bumper...
Damn you Stu - modding is meant to STOP when I've done this conversion! :finger::rofl::D
edit: You mean a little like this photo-chop? Done a while ago this was, when I had my current exhaust but the old bumper. :D
Doing well mate, well done for sticking with it :D
Nice to hear its coming along :)
Good to see your still enthusiastic, despite the many problems you've had :rolleyes:
Keep the updates coming :thumbup:
This engine swap lark is fun!
We do have more fun trying to overcome the LITTLE knockbacks.
But you are persistant and that pays off.
Good luck and DONT FORGET TO BED THE CLUTCH IN. ;)
Sarah
Sarah
I won't! :P Gonna be treating her gently for quite some time until I'm 100% confident the conversion has been a true success. :thumbup:
Jay keep with it, glad it's going better now :thumbup:
Will you be exploring the "Ring" in september?
