Portable Pressure Washers for washing cars (no tap needed)
I'm sure there are loads of you that are in the same position as me.
I have to lug buckets of water outside to be able to wash my car as I don't have an outside tap.
So now I've decided to look at a portable pressure washer, it plugs into a 12v and gives you a water jet supply.
First one that's been recommended is the mobiwash power washer 25L - around £100 to buy. On a video it looks quite a good constant pressure.
Has anyone had any experience with this portable power washers?
I'm quite detailed in when I wash my car and like it to be spotless, so a good washer is essential without spending the earth on one.
Thanks,
Ollie
No idea on the 12v ones, but you can run most pressure washers from a bucket of water. I haven't got a tap near the workshop, so I just fill a 5 gallon drum up and drop the pressure washer hose in that.
Living in a block of flats, and lugging 3 buckets of water down to wash the car is a pain!
It sounds daft, but I have 2 buckets of fresh water, and one with shampoo, I sections starting from top to bottom and I use a jug to rinse it. Neighbours think I look a bit weird watering the car but it works for now!
Wash car in the rain. :sun:
Do you know if it does a good job of cleaning / rinsing it?
The 12v ones have a unit inside it which you fill up
Mine doesn't seem any different whether it's running off a tap or out of a drum. The only thing I'd say is if you're running it out of a drum or a bucket, use a short hose for the input.
