In a spot of bother :(
I'm currently trying to upgrade my rear brakes and so far have managed to remove the calliper and one of the carrier bolts but the other is in a bit of a mess.
When trying to loosen it, the wrench slipped and I have managed to mangle the opening of the nut...
Looks all ok inside but I can't get the attachment to sit all the way in, so my initial thought was to bang on the wrench attachment, re-gouging the hole and giving me the purchase needed, but I don't have enough room the generate the power. :(
Was wondering if anyone has any bright ideas?!
  • Replies 54
  • Views 4.8k
  • I'm not one to get drawn into this type of thing, however.... Jesus! I don't think I've ever seen a post from you that wasn't condescending. The point of the forum is to share knowledge, and that's
  • I have a mapp gas blowtorch you can try mate.  Also have a small cordless impact driver which may be able to  crack it undone. I'll catch you tomorrow.
  • Hacksaw blade and run in a line across the head. Then you can use a flat blade screw driver.
mole grips / water pump pliers to crack it ?
weld a nut on end?
Heat it up with gas and get mole grips on it? Doesn't look too bad
Knock it round with a long chisel.
put it all back as was and forget about upgrading :)
I've got some water pump pliers I can try.... no heat gun yet, but on the list.
If I can get past the opening, it does look ok in there, but I just can't bang it hard enough :(
I'm upgrading as the O/S calliper is goosed :(
Hi
Had the same experience the other day. Mole grips did it for me. Heat is a good idea too.
Part number for new bolt - N 90740302
Alan
Try a torx ot "star" bit see of that will do it if you've already rounded it off, if not sharp chisel and tap it around ;)
Well I've packed up for the evening now after giving the mole grips a go but couldn't get enough purchase, but I will be back at it again tomorrow.
Cheers for all the input so far. :)
H&S tip for leverage work in a confined space:  heavy work gloves (gardening gloves at least), for when the b****r slips :doh:
Take the disc off and press the tool into place using a clamp or vise-grip, once pressed in, gently heat the casting, apply a squirt of penetrating fluid, tap around the area, undo, profit.
Repair the bolt by peening the burred end over with a ball-pein hammer and hammer the tool in until consistently shaped, refit.
Can you get a dremel in and take the head off?
Dremel: don't own one yet, but can get my hands on one if I need. Will look tomorrow afternoon once I'm done elsewhere.
I need to get one of those sets in my kit Fordfan, look pretty good.
Yes Garry, that would be awesome. Cheers mate
I was going to say what Matt H said but he beat me to it. Good luck, hope you get it sorted.
And yes those Irwin sockets do look good too.
Not got a stubby drill?
Get some penetrating oil on it asap - but NOT on disc or pads!
No :( Borrowed a posh blow torch today and will give that a bash
All bolts were pre-soaked with it, just this one is more stubborn than me that's all :D
What I would do before doing any of the above is bash it really hard with a club hammer and a drift, normally this will shock the fastening and it will reshape the head of the bolt, you may even be able to use a proper Allen key socket in it still.
I've got the proper Allen key socket (I was using it when this happened), only have a claw hammer or a rubber mallet and not sure what a drift is? Kinda new at this :)
Use your hammer, not the claw side obviously... hit it hard, repeatedly. Then it will just wind out..
