Cam belt kit
Gates is the best
I meant to do with bolts ? can anyoen advise?
While on the subject of kits here ECP have the circoli water pump down to £35 from £81 are they any good?
bump on this again for what engine bolts are required... anyone?
N10209603 x 2
N10516701 x 2
They should be in stock at a skoda garage for when they replace a timing belt.
I bit more info can be found in this thread: http://www.briskoda.net/forums/topic/311549-engine-mount-advise/
When I came to order mine they didn't have any N10516701's so had to order them in anyway. The part number is now N10516702 I believe.
All four should cost about a tenner.
Edited by Bobmonga
Can these bolts be fitted after the cam belt has been fitted as I dont think mine have been changed?
cheers
Drew
Yes, I think the stretch bolts are accessed from above and go down through the mount into the chassis.
