Felicia clutch pedal
Hello.
I just bought a 98 lxi felicia. Is it just me or does everyone's clutch pedal stick out about 2 or 3 inches further than the brake and accelerator? It seems very odd it shuould be like this as you have to lift your foot quite away of the side rest pedal thing to reach the clutch. Also i found a broken srping attached to the clutch, is it meant to be there?
Thank you all for helping a newbie on the forum.
Mine isn't - worth checking the cable adjustment its detailed in the haynes manual as follows:-
The Clutch cable adjustment is set by checking the clutch pedal height in relation to the brake pedal. If the cable is correctly adjusted the clutch pedal should be level with the brake pedal (-+3mm) and there should be no freeplay in the cable If adjustment is neccesary proceed as follows:- Working in the engine compartment locate the end of the clutch cable which is sitiuated on the top of the transmission unit remove the locating clip from the inner cable and adjust the clutch pedal height by rotating the adjuster nut in the threaded end of the cable. Once the cable is correctly adjusted refit the locating clip to the end of the inner cable ensuring that it is tight against the release lever / mounting bracket as applicable
John
cable adjustment only adjusts the pedal height and yes there should be a return spring fitted.
