Newbie
Used this forum for ages as a visitor and decided today to join.
I have a Fabia 1.4MPI 2003 my Daughters old car so not too exciting but, reliable, economical and room for everyone.
Welcome :)
Welcome
16v or 8v? We've got the 8v which, apart from being underpowered, is going strong.
8valve which as you say apart from the lack of power is a nice driver.
Have a real problem with water ingress into the nearside rear foot well, sealed the doors as recommended and it does not appear to be coming through those if indeed it ever did but still getting water inside, only seems to be the rear foot well with the front getting wet from the water in the rear, boot dry as are areas under the rear seats and over the handbrake tunnel so only thoughts now are from the sills although the drain holes are clear. Going to remove the interior again this weekend and hose it down again to see if I can see where it is coming in from.
Good luck with that one...
Welcome  :hi:
Hi and welcome aboard.
