odd one... biggest intercoolers people are running?
Think you have to take the slam panel off to get to the bracket and can move the drivers side some how. Never looked in to it just what I have read before from people fitting other coolers.
  • Replies 53
  • Views 3.5k
  • Realise this. The more pipework. The more air needed to fill and more lag. Just trying to work out if I can fit this cooler into the space and how to best run pipes before I go spending any money
  • My old man fabed a bracket up for me, you can see the two large torx screws it uses and it also fixes to the bumper support aswell.
  • You probably wouldn't notice the lag as said. The other way to do it is to run a single pass cooler and passat inlet manifold to reduce the pipework.
Cheers. Ill look into it :)
Well mini check list.
intercooler yes
couplers yes
will power yes
Pipework... a few bits (60mm to 51mm reducer 90 degrees and a meter of 51mm ally Pipe)
Gonna get the crash bumper tpok off and altwr it during the week. Then weekend I can hopefully mount the cooler and start on pipework from turbo to cooler. Then im gonna focus on the top pipes next week
Dependent on if my pipe bender will work on ally piping, ill either one piece the top pipe and get a map boss welded on or if the bending dont go to plan. Ill have to buy multiple pieced haha
funds ...
Turbo pluss egr couplers bought
all pipework from turbo to cooler ordered all 51mm
Forge map sensor pipe ordered as its 60mm. Darkside one was 57mm.
Couple of the top pipe pieces ordered but not allot as I dont know what ill need properly yet
so we are starting to get somewhere now :D
