octavia vrs calipers vs standard fabia tdi vrs ones
ie if possible to do the coversion with just carriers discs and pads do the octavia pads fit in the fabia vrs calipers ?
You need calipers too
Though some MK4 platforms had a 288mm brake setup, the calipers and carriers are apparently not compatible with our 288mm setups. Whether that's down to disk offset or carrier pin dimensions or elves :) I dunno.
J.
