Climatronic settings
Hi guys – I have a question about the setting that is not clear in the manual. There is the “Auto” settings button high and low and the “Air recirculation/Air redistribution” button. My question is what is the difference between having the “Auto” set and having the “Air Redistribution” set? The related question is why when switching on the Air Redistribution does it switch off the “Auto” setting? Should we use both the “Auto” and “Redist” settings at the same time?
This is not clearly explained in the manual and I fiddle with it often which is distracting hence my question.
Many thanks,
Oh thanks Mike - What effect does having both “Air Distribution” and Auto on at the same time? Is there any point? Also if I just have “Air Dist” on will that regulate the set temp too?
And do you know why the air con comes on when in “auto” mode when there is no need for it? I mean when there is no danger of the windows misting up?
Thanks for your advice,
