driver's door wont open from the inside
The drivers door unlocks fine, opens from tge outside fine, but wont open from the inside.
When you pull the lever it feels like its not connected to anything.
Any ideas before I pull it apart?
Broken handle or cable would be my guess. You'll have to pull the door card to see whats going on.
The cable has probably sheared off where it connects to the handle. I replaced my drivers door one last week. Got the cable from tps for under a tenner. I manged to connect it the the door lock mechanism without taking it out.
Same just happened to me cable cost £11
I found on mine that crimp joint had failed at the internal handle end, and had basically allowed the cable to stretch.  I picked up a new one from a dealer, but last time I was down the scrappy I picked up a spare one.
