Y et another leaking sunroof.
Hello guys!
My good ladies 2004 MK1 Octavia sunroof has started leaking. I've had a look and I can't for the life of me see the drain points on the sunroof. I've had a good look through the search and only found reference to the "sunroof drains diagram" but not the actual diagram.
Can anyone link me directly to it?
Thank you in advance
J
Park the car on the level.  Open the sunroof.  Use a bottle of water and pour a little into each corner of the opening.  You should almost immediately get 4 puddles on the ground.  Which ever puddle is smallest/slowest is probably the drain which require attention....
Hello guys,
I tried the water trick, to only find it gushing through the head liner into the cab.
I removed the internal trim around the  sunroof. It has no drains. Anything that gets beyond the seal just comes straight into the cab. I checked my L&K and that does indeed have drains and a sealed area for the water to go.
well..... was that a factory fit Sunroof, or was it installed by a previous owner? if after market it would explain the lack of drainage -
they just can opener'ed the roof and put the unit in.
That isn't standard.  The standard one slides into the roof (at least on my estate).  Post some internal pictures of it & the controls.
what drew my attention to it being after market was the seal on the outside of the roof.
it didnt look right..... nor did the glass over the roof look right for a factory jobby :)
