Camber on the rear wheels
Took my car to have its wheels aligned as it was pulling to the left after I fitted my coilovers.
The garage corrected this, but on the readout, it shows my rear camber to be completely different either side.
Now it is my understanding that the Fabia is a solid beam, and as such, isn't adjustable. So how can I be running different camber on each rear wheel?
Many thanks :)
Mine's the same fella, however there are shims you can get apparently (not sure where from) that you can adjust the camber etc with.
Thanks guys, wanted to avoid the shims, but ahh well.
How are these used???? do they fit front and rear and can you use them to adjust wheels that are showing positive camber back to negative camber????
Dave.
Surely you'd be better off trying to find what's causing the camber (something bent?) and fixing that?
What are the rear camber readings? Could be .000 degrees different or a few degrees different. Would have to be very different to indicate anything being bent
So when lowering the car theres not much you can do with adjusting the front that doesn't involve lots of £'s
Dave.
Dave.
there is a small amount you can move from left to right but no actual adjustment unless you buy adjustable top mounts like Kmac ones which are around £400 :(
