Sorry! Another rear brake upgrade question!
VW Golf MK4 V5 Rear Brake Calipers 256mm Vented Discs
Will the above fit on my VRS mk1 fabia with 17" spiders?
Yeah, they fit under standard fabia vrs alloys :)
That would depend if the above MK4 V5 is 4Motion of not.
The Rear carriers are different to the 2WD version. I've heard rumours of people modifying them to fit but i don't see the point as you can pick up Brake kits up off the 2WD version easy.
There is no V5 (2.3 litre) 4 wheel drive version. :)
Its the V6? lol
Damn my bad!  :giggle:
Yeah, you get 2.8 V6 4 motions / R32 etc etc.  All with the rear brakes that need a bracket / don't just fit right on
I have a full set of 256mm rear brakes painted red with almost new discs and pads if you are interested? £100?
Thanks all, Happy days :-) !
Thanks for the offer Joe but I literally just bought a set earlier this morning, if only i knew before!
Received the new setup, callipers covered in brake fluid, any easy ways of removing? I can't paint them otherwise :-(
Brake cleaner, takes it off and drys within seconds!
Thanks mate! Never knew it was soo simple :-)
I'll pick some up after work
Gotta love this forum!
Anyone know what these holes are for?
Meths works just as well and is cheaper, plus you can wash them in soapy water straight after and use a toothbrush to get them really clean before painting.
Thanks mate I'll try soapy water too, how about inside the caliper? Do I need special liquid?
