XDS activation
Hello,
Is it possible (or a good idea) to enable XDS on my pre-fl CR VRS?
The car has the standard "ESP" button, so I guess this means EDL as standard.
Just like to know if it is doable with VCDS really, or am I liable to break something!
Here's the ABS part  of an Auto-Scan I performed the other day, which might help.
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 163B601C09220002680D06ED901B00826C00
   Shop #: WSC 73430 790 00000
   VCID: 74E73A5BD74EF4BE80B-8021
No fault code found.
Ta.
It didn't appear until after the first round of FL cars so I doubt you'll be able to get it.
If you have a cr then you have a face lift. Your pic is of a facelift too.
I don't think AD supports XDS
The CR engine actually came in before the FL car but you're right, the rear light is a FL one.
Is'nt it hardware dependant? You need the right sensors and wiring rather than just ticking a box?
it is the pump that allows the function
Like Hill-Hold
I have a pre-FL CR :P
I have a pre-FL CR :p
Me too, and many others.
This looks like no go then, if even early fl models didn't have it.
I suppose VAG felt the need to initially omit it from the Skoda range, as so not to hurt VW sales too much.
Edited by Fr0d
