Front Splitter.
Can someone point me in the right direction as to where to buy a front splitter for my VRS (07) .
Cheap as poss £50 is reasonable. That will fit easily and is not a universal type that requires loads of modifications to fit.
Cheers.
That helps! Is that 159.99€ - Euros?
What's that as pounds. I guess I'm going to have to dig dip for this. Seems stupid as it's just a bit of plastic -_-
Go to your local SEAT dealer, got my cupra r splitter for like 60-70 quid i think it was! pretty easy to fit with VERY minor modification (trim a small part down)
easy peasy  :rock:
Less than 30 quid I think (Lip from Seat)
Edited by alberg
I'm going for the Cupra R splitter.
2 questions -
What size self tapping screws do you need and how many?
Also, when it comes to ' trimming ' the splitter. How do you do this? Saw? -_-
I have some pics at home. Later will put them on here.
Thank you! :)
Pics would be good wouldn't mind trying it on my pre fl ltd edition
+1
£44 inc VAT. Max 2 days delivery as they've had to order in. Will let you know how I get on with fitting.
I first made holes on the lip. It has pieces that stick out.
After drilling hole and fixed under bumper i passed the drill again to make the hole on bumper.
The ends of the lip was cut off as it was bigger than needed. I used stainless steel bolts.
Meanwhile had the lip painted to match cars color.
