KESSY/Remote problem
Hi, I have a 2011 3T estate with KESSY. I'm having problems with all the comfort functions in the driver Door, even central locking on the driver door (left hand). The left back Door is also acting up (central locking). I've checked fuses - no problems. I belueve this problem showed itself after a machine Wash. IF i yank the cable between driver door / body it starts to work but only for a few lock/unlock cycles. Any suggestions ?
Edit: the error is present wether I use KESSY or remote unlock/lock. Power Windows fail aswell ( left Doors)
Edited by cobreti
There have been some problems with the wiring loom between the body and door breaking where it goes through the rubber duct.  Perhaps start checking there.  A VCDS scan would show "intermittant/implausible signal" in it's logs if this was the case.
Thanks, yes some reading on the board gave me the same suggestions. I haven't found any good info on how to remove the door panel, any tips there? Hmm, I dont have vcds but I can test a generic reader and see what turns up.
Anyone know how to remove the driver door panel on a 2011 superb?
to remove trim You need to remove firs the switches panel - just pull it up with some plastic tool
then unscrew 2 torx screws
then remove the speaker grille and unscrew 1 small torx
at the end unscrew 2 torx at the bottom
using plastic removal tool (or just secured screwdriver), start to remove the trim from bottom - it's some of plastic bolts underneath - You need to do it firmly
it's good to purchase some new plastic bolts for trim at Your dealer - just in case You destroy one or two of them
when You hae everything loose unsecure the electric scokets and pay special attention to the plastic element of the wiring to release
here some piscs:
https://lh3.googleusercontent.com/-6G6QHrQcv7Q/U4Or3E3p8QI/AAAAAAAAAug/Q2obzdbmZ-Q/w979-h549-no/DSC02605.JPG
https://lh4.googleusercontent.com/-z67juFHrixs/U4Or3Gq6GkI/AAAAAAAAAuk/tHCbDA9PfWs/w979-h549-no/DSC02609.JPG
  • 2 months later...
Thanks for that instruction, worked flawlessly! I had to replace the Wire harnes in the door. Was a PITA to get to the connector for the door lock :-/ but with a few 4 letter words I got the job done :-)
Edited by cobreti
  • 1 year later...
I was fixing my car today with your help guys :-)
Thanks a lot.
Good tool for door panel removal:
12694532_10208131000780395_7111422076525
Here is my problem,green wire broken and red and brown both damage:
12622543_10208131000660392_2950993046479
12615769_10208131002260432_2728666851602
10317630_10208131003220456_3272077100619
12657451_10208131000700393_6647077169177
