Converting headlight beam to LHD pattern
Hello all,
I wonder what's the neatest solution to convert regular facelift mk1 headlamps to an LHD beam pattern? I have a set of stick-on converters, but I reckon they'll be welded on after a while in use. I was half-thinking about sticking them to a set of headlight protectors, but they're rare as hen's teeth, and expensive enough too. On my last sojourn I didn't bother with any converters as I was doing no night-time driving, but I'll definitely be driving at night this time. Is there a more obvious solution (reusable converters maybe?)
Thanks a mill :)
You could buy LHD units
This. If you're willing to spend money then that's the route to go down, but if not then the sticky converters are the only realistic option.
Ah OK, thought it was worth posting the link just in case.
