boost leak test
hi all
I think I may have a boost leak on my vrs, what would be the best way of going about testing for this?
I know there is a lot of talk on here about boost leaks but haven't been able to find a definitive way of testing for one
any help would be appreciated
thanks
visually check all boost pipes (excessive oily mess at one of the joins) and check for excessive play at the joins (they move slightly anyway but if the metal lugs look past it or if you can pretty much pull the join apart easily with your hands)
still unsure then you can do your own boost leak tester (google how to make boost leak tester) or take it to a tuner that does a boost leak test
excellent, thanks mate.
I'll have a look at them over the weekend, I'm having some hesitation when trying to accelerate but only sometimes, if they are fine at least I can rule that out
thanks
Edited by soul snatcher24
