Fog light question
No, they are for the facelift.
They will likely fit the aperture on the pre-FL vRS but the mounting locations at the back are different.
They will also need resistors adding to cancel the blown-bulb warning.
The only MkII Octavia to get the round LED DRL's is the Scout...
Ok thanks just threw me as. hey list the part numbers for the following under the description.
ELECTRIC PLUG: 1J0973723
PART NUMBER FOR WIRE: 000979133EA
Which I took it as needing the extra bits to fit them to my model.
Info from a skoda dealer tells me they will fit with some different connections as one of their staff fitted them. Just need to see switching the bulb check function off on vcds.
I've fitted them on my fl octavia if you look at my photos your see them I fitted a resistor to stop the bulb error when wiring them black wire in the middle and the red on the curve side not the flat side for 100% brightness.
Is this possible?
Is this possible?
Not had a chance to look today unfortunately. It's just something that was mentioned in a thread I read.
Will report back.
Interesting read,
Incidentally, could I buy the LED DRL's and plug into a scout facelift model and they'd work straight off the bat or is some wiring and messing about required. Looking for a FL scout & these would be something I want to fit to it....
