rear view camera
Anybody fitted rewr view camera and screen
  • Replies 60
  • Views 29.9k
  • Just recived 2 rvc for the O3 from juq-performans (stefan) A small rvc (aftermarket) and a large rvc (original) The new (2015) O3 estate is coming with a larger boot button than the sedan. Same butt
  • I retrofited the rear camera in my O3 MY14 with Bolero MIB, same for amundsen.. You must connect video signal to pin 6 and 12(gnd)  of Cd/sd unit, blue connector. Power the camera with 12v and codify
  • http://www.ampire.de/Multimedia/Multimedia-Interfaces/-fuer-SKODA/-mit-MIB/-KAMERA-EINGANG/AMPIRE-Videoeinspeiser-kein-Ton-fuer-VAG-MIB-Standard-High.htm?shop=ampire&SessionId=&a=article&P
You can't get the octavia with oem rvc. But you can code it to work on bolero and the satnav's. But what camera you have to use i'm not sure. Maby a universel number plate light with build in camera and a interface too trancelate the signal to det infotaiment system
A system is available so you can use the OEM screen to display external video sources - camera, xbox, whatever - but its somwhat pricey - about nearly 400 quid if i remember correctly
I'm guessing this is just for the Columbus.
Was hoping to get wireless aftermarket camera, but dont think
Can display on an Amundsen...
Rear View Camera available for Octavia HB and Combi order. Delivery September onwards (Option Code  KA1 - Optical Parking Assistant).
Option cost around 300 Euro.
Rgds.
Edited by dsg8
So for a reversing camera you would need to install this and an aftermarket camera and then you could have a reverse camera with the guide lines like you can spec on an A3 or Golf?
Must admit that's kind of tempting, but not sure whether that's something I would attempt to install myself :(
With rear parking sensors is there any point though?
Dunno, not had any issues with the sensors yet, they have been pretty reliable so far, would be nice to see though. Starting to get used to driving an estate car now after switching from a tiny car :)
It's now a factory option. I'm likely going to retro fit.
So far Advanced In-Car have tentatively quoted £850 - once I have a VIN they'll be able to get an accurate cost.
Anyone else recommend a VAG specialist in the South West?
You need to spec Amundsen or Columbus for the factory fit camera. Would a Bolero take a retrofit? Or does it lack Video-In?
The German link above suggests either Sat Nav or Bolero is good for retrofit.
Can't you get it added to your order or have you been allocated a build week?
I added it to my order a couple of weeks ago and it was confirmed that it would have no effect on the build week (which I am still waiting for).
Being built next week...
Shame as it is a fair bit cheaper from the factory ...
Tell me about it! Oh well. It is what it is. I still hoping to get that tentative figure much closer to £600. TBH, I'd be happy to fit it myself, it's pretty simple and I have a VCDS friend.
It is the wiring that will be a pain - removing all of the trim to run it from the trunk lid through to the dash.
Yea, it's just time though, not difficult. I'm a geek so should be fine and likely save a couple of hundred in labour.
Agreed, but getting the trim back on to the factory standard can be a pain, especially with the trunk lid trim. Buy some spare trim clips :)
Is there anybody who is willing to do this and post it here explained with the VCDS coding and the exact rear view camera used? I am keen on the idea and I've been following the thread since it started...I'm just not sure how to do it  :sweat:
I'll post the details when I get round to it no problem.
There is a shop on E##y that sell camera kits for VW's, not sure if these models would be compatible with the Skoda units or if these are for the older VW ones.
Fit vehicles equipped with head unit VW RNS 510 / RNS 315 / RCD 510 (with 26pin connector).
Would be much better if Skoda did the emblem camera like on the Golf GTi's but these are a lot more expensive.
