rear view camera
Very useful info.....
Good.
Always aim to be constructive with my comments.
Edited by vrskeith
  • Replies 60
  • Views 29.5k
  • Just recived 2 rvc for the O3 from juq-performans (stefan) A small rvc (aftermarket) and a large rvc (original) The new (2015) O3 estate is coming with a larger boot button than the sedan. Same butt
  • I retrofited the rear camera in my O3 MY14 with Bolero MIB, same for amundsen.. You must connect video signal to pin 6 and 12(gnd)  of Cd/sd unit, blue connector. Power the camera with 12v and codify
  • http://www.ampire.de/Multimedia/Multimedia-Interfaces/-fuer-SKODA/-mit-MIB/-KAMERA-EINGANG/AMPIRE-Videoeinspeiser-kein-Ton-fuer-VAG-MIB-Standard-High.htm?shop=ampire&SessionId=&a=article&P
My brand new Octavia greenline has Amundsen and a rear camera. Factory, not aftermarket. If you don't believe me I can post a pic.
It's been available as a factory option for a few weeks. If you want to help, get a VCDS scan of the car with debug level=2 and send it to Ross Tech so they can help us with the coding when we retrofit :)
http://wiki.ross-tech.com/wiki/index.php/Control_Module_Maps
I found this http://www.cars-equipment.com/www/en/shop/rear-view-cameras/oem-5e5827566c-rvc-lowline-camera-for/ . A friend of mine said ''pin 6 for video signal , pin 12 for ground connection (blue)
Unfortunately I don't know where are these pins :D
If you can read German - take a look at this forum: http://octavia-rs.com/wbb/rückfahrkamera-nachrüsten-car-hifi-navigation-und-multimedia/skoda-octavia-iii-rs-5e-f200/t18102-f217/index3.html?s=5b116d00d351515d5fc451d649ad351630e4a656
They use a different camera than Skoda OEM but it seems the only difference is the color of the guidance lines.
  • 1 year later...
Hello. I ordered a backup camera in China. after much research, I still do not know where I'm going to connect my camera. I have an Octavia Rs 09/2013 with the Amundsen navigation system. Can you help me please ? thank you very much.
I retrofited the rear camera in my O3 MY14 with Bolero MIB, same for amundsen.. You must connect video signal to pin 6 and 12(gnd)  of Cd/sd unit, blue connector. Power the camera with 12v and codify with VCDS Adresse 5F (Infotainmentsystem)Byte 19 - Bit 4 enable.
If you have park assist codify:
Adresse 76 (Einparkhilfe)
Byte 02 - Bit 4 enable
Note: Some Bolero cd units not have video input (5E0035819A or 5E0035812A...20A)
Edited by caf28035
I ve added a pioneer AVIC F260 VAG unit to my bolero and it gives me sat nav and has an input for a rear view camera so the bolero radio is capable of a camera
Discovered that mines already got a factory fit one.
Just sayin'. :blush:
  • 3 years later...
My Bolero Mib1 is 5E0035819A, so i cant install a revers camera?
