Columbus WiFi / Data not working - refused by
Thanks. My friend has a computer, etc is there a log on?
  • 4 months later...
  • Replies 55
  • Views 9.1k
  • Is it the wifi menu you are looking in? It may need coding, mine did, it wasnt set up for wifi... I had to change the last two digits to 0101 in the long coding. Adam
  • You understand me correctly. Have you entered the details of your apn in the settings. In other words, I mean your phone's data profile. Adam
  • Its basically the settings you apply to your phone to enable it to use data. Effectively it tells the phone the carrier of the data service e.g. o2, vodafone or your provider in Turkey. There is a set
You need access to VCDS and it is done in the long coding for module 77 telephone.
ย
If you haven't got VCDS, there are members around Manchester who will help - check out the map in the VCDS and diagnostics part of the forum.
Hi Adam
Are lay people able to get their hands on VCDS?
BTW Bluetooth unit is ย "3C8 035 730 C".
I have managed without wifi but I would love to get it to work.
Edited by maxp
Hi Adam
ย
You can either buy your own VCDS cable at about ยฃ270 or see if a local member will help you out. Couple of good threads to find someone:
- http://www.briskoda.net/forums/topic/262215-list-of-vcds-owners-previously-known-as-vag-com/
-ย http://www.briskoda.net/forums/topic/224376-vcds-owners-map/
ย
A 3C8...C unit won't support WiFi. Only the 3C8...D and 3C8...E versions do I'm afraid :)
ย
ย
So I guess its not possible, without changing the BT unit
No as langers2k states it is only the 3c8 ... d or e modules that do wifi.
Edited by adamal
  2. Tap Permissions โ†’ Notifications.
