Yeti roof bars / kayak carrier
Can anyone offer some advice, I have purchased the Skoda roof bars for my YetI and want to carry my soon to arrive kayak but unsure of which carrier to buy. The kayak is 13ft long and I will only be carrying the one so preferably on its hull not side.
Thule type I spotted is around £180, ouch. Would like one that was also locking. Any other options / recomendations.
I think Johann, 900000000000000000, carries a kayak some times.
I'm a bit dim. Cannot you simply strap it to the roofbars if it is not on its side/edge?
Colin
Colin
I could, possibly,but it might fall off.
Ratchet straps from halfords are your friend........
The trouble with that is you end up distorting the hull having to pull them in tight enough, whereas using a proper cradle you don't have that problem
Llanigraham, spot on, that's what the Kayak shop told me, unfortunately they couldn't advise on a cradle type as they only supply the type for transporting on its side. The Thule cradle looks very good and it's lockable but £180+. I can't seem to find any other makes that are similar and lockable.
http://www.thule.com/en/gb/products/carriers-and-racks/water-sport-carriers/kayak-and-canoe-carriers/thule-k-guard-840-_-840000
I carry my sea kayaks with straps and 2 vertical bars they are very robust, hard plastic, and do not distort.....
Fine, but "servicepoint" says he doesn't want to carry his vertically!
We certainly found that when we carried my son's kayak on just the bars the hull always ended up with dents in the bottom where it was pulled tight across the bars. Luckily he joined the local Club and kept his there and used their transport.
I know a few people made there own cradles with some thick plywood.
There are loads of options (cheaper too) for carrying them vertically, perhaps this is the more 'economical' way for me to go, I just thought that as I was only going to be carrying one I would rather it sat flat on its hull.
Service point, which you can lay it flat and use ratchet straps...... Like I have done in the past on numerous occasions , unless I'm going to be told that I'm wrong again........
What type of kayak?
I had a plastic sit-on and just strapped it face-down to the bars. It wii of take far more force than a tie-down strap to distort the shape. Some advise also typing the end (s) to your tow hooks.
No one has said you are wrong, only that I found doing it that way resulted in a dent in the hull of my son's kayak that often took a long time to come out, and which I, and others, thought might lead to permanent damage to the hull.
EDIT.
This was my son's kayak:
http://www.nswatersports.co.uk/kayaks-c10/whitewater-kayaks-c11/pyranha-kayaks-zone-river-play-kayak-club-spec-p1075/s5554?gclid=CjkKEQjw_N-cBRD2k73X3OjJ8eMBEiQAbdPic04INVNbAZiASO2_XAplq0cwguK_9LD47SmJXDAXMizw_wcB
Even if I resorted to the vertical carrier, I can't find any that locks the kayak other than Thule.
Wakev, thanks , first one may be an option, I'll perhaps have to sacrifice being able to lock the kayak... or pay £180.
That's actually a decent option wakev, does bump the price up but still a lot less than 180.
Thanks for that.
