No AM Radio Signal!
My FM radio is crystal clear, but I get nothing at all on AM. I've tried a different aerial but the exact same thing happens
It's an 08 Fabia 2
Any ideas most welcome - cant be missing worldcup matches on 5 live!
Thanks,
Ben.
AM radio... I haven't switched to that since.... hmmm can't even remember.
Normally around the UK i get AM that can be listened to, just,
that is in different cars, recently AM has been so poor on 909 i have not been listening
& 1053 is only a little bit better.
So basically, is it the same for others, AM near at end of life in the UK.
Sounds like you need to tune to 693 and 1089.....
Sounds like you need to tune to FM or possibly DAB.
I thought it had been switched off to allow 4G. Then when fm is switched off we get 5G
Sent from my SM-G900F using Tapatalk
MW is on AM and isn't working...
FM works fine - but no 5live on fm!
Surely this isn't right - nobody can pickup 5 live on mw???
Never tried MW - got Radio4 on LW all the way to the German border last year though.  Got a bit patchy through southern Belgium but still managed to hear and understand "Sorry, I haven't a clue"..
Minimal,..worth checking online for any shutdowns/planned works.
Not sure where you are but Droitwich transmitter (effecting certain frequencies)is being switched off for repair/upgrade works on a regular basis and has been for a while.
Just a thought.
Link to full list of transmitters (I know it says TV but it includes all radio station outages as well):
http://www.ukfree.tv/reception_transmitters_index.php
Or your car antenna could be duff...try built in radio in your mobile as this uses the ear cable for radio reception, so if that is poor/non-existant too then your local transmitter could be off?
Edited by Defenderben
MiNiMaL_FuSS,  where are you located & trying to get reception on AM?
I thought it was '5 live' i was listening to on MW  909 or 693  & Talk Sport on 1053.
The other one i tune in is 810 MW for Radio Scotland on Saturdays.
(Because there are different programmes from the one i want on FM or Digital then)
My point was,
when ever i try AM/MW now, the reception has become very poor.
Location, location, location,  & reduced Power Output i thought not the Reciever Equipment.
george
As goneoffSki says, MW AM is poor and  needs a signal booster. Your car has one fitted at the base of the aerial. If you cannot get AM or MW then the booster has failed. You will only get FM. Water sometimes gets into the aerial booster, or it just fails. Replace and you should be able to listen again.
I had that on an old Octavian. A new aerial fixed it. Horners said it was water in it....
You can get a powered car antenna FM & AM signal amplifier from Amazon for £3. There is no such thing as an unpowered AM signal amplifier. God only knows why BBC Radio 5 Live isn't available on FM?
Ah a helpful answer!
How do I go about replacing the aerial booster???
  • 4 years later...
