No sound on stereo and tips how to fit replacement stereo?
Hi all I bought a mk2 2006 reg octavia vrs last week and am loving it (had a mk1 in the past too). I switched the stereo on last night to find no sound but the cd and radio were operational. When I got home I switched the ignition off and on again and the sound worked fine. I just wondered what may be causing this and could the stereo eventually pack in working?
Also I was thinking of replacing the stream stereo with either a single or double din one with a usb feature. Does anyone know of a decent fair priced fascia I can get that doesnt look shoddy and also what else I will need and any problems I might and inevitably will have whilst fitting it?
Isn't there a 'turn on' volume setting?
I had a Pre FL Octavia with a stream in before and It would occasionally do that...Usually when it was playing an MP3 cd. It only happened about 3-4 times in the 2 years I had it, so I didn't put too much thought into it...Definitely not a 'turn on' volume setting though as it did it mid track on 2 of the occasions.
the usual suspects make facias, search car audio sites for those. You can also buy them direct from skoda but its not cheap
Also did the same on my Stream while playing MP3s.
Did it quite a few times... so upgraded to a Columbus.
Phil
Thanks. So if I buy a fascia is it as simple as buying a lead for the skoda and popping in my pioneer single din stereo or is there more to it?
You will also need to run a wire to the fusebox and pick up a switched live otherwise the stereo will be on all the time due to the can-bus system.
Phil
Are there any tutorials on doing this?
You'll also need a wiring kit as well as facia, since your current headunit will have a quadlock connector whereas the single din pioneer will most likely be ISO.
Or you can buy a wiring harness which means you dont have to run a wire to the fuse box
