Rear jet washer
I can't help but notice that sometimes when pulling off from junctions etc my rear washer jet just seems to ooze out some washer fluid, it's not very often and it's not directly after using it, it only seems to happen every now and again and I'm just curious if it could be something with the heat maybe expanding the opening where the washing fluid comes from..?
Sent from my GT-I9305 using Tapatalk
Happens on mine from time to time.
No dribbles here :notme:
I think it just gets  " Excited " with it's self     :notme:
Real tempted to mark that as solved :giggle:
No dribble here :)
Sent from my IPhone 5 using Tapatalk.
Mine's slightly incontinent as well....only 9 months old....
Also the washer jet dribbles down.... doesn't spray.... bit annoying..... can it be fixed?
Do you mean that it just dribbles out when you use it?
I get an odd dribble since I was rear ended....only sometimes though.
We still talking about the car right? :peek: :D
mine dribbles too.......could it be crud in the jet? really annoying as you get 'streaks' down the rear window!
My car's just over a year old and has had this annoying trait since new. It does it in hot and cold weather and whatever the level in the screenwash bottle.
Hyphons.... it gentle streams across & down the rear windscreen.... doesn't spray.....
No dribbles here - is it age related ? (to the driver) ;)
:o :no:
54 and mine does not do it.
I can get you lads some Extra large Tenna lady's at a good price.
Does it do it when going in reverse? if not problem solved.
I've seen it on mine and a Rapid I recently had as a courtesy car.
Unfortunately it's difficult for the vehicle to get two shakes in around there.
May be worth while speaking to the garage then
I'll add it to my "list"....
