Will these tires fit my VRS?
Hi fellas, sorry if this is a dumb question as im not the most savvy when it comes to motors, my 54 plate vrs currently has 205/45 2R16 87 WXL tires fitted but they are getting rather worn, my sister has some 195/65 R15 tires lying around(taken off a golf before alloys were fitted) my question is, would these be suitable for my VRS or not?
All help is much appreciated
Not, wrong diameter.
As said above, the Rim size is 15" on the new tyres and your VRS has 16" rims.
So no.
ok, thanks fellas
Just to try and help you a little further with an explanation of the tyre size:
205/45/16 means
205 = width (mm)
45 = side wall measurement (mm) (I think)
16 = diameter of wheel (inches)
205/45/16 means
205 = width (mm)
45 means the height, or aspect ratio, which will be 45% of the width.
So, 205mm width * 0.45 = 92.25mm side wall measurement.
I really must get out more.........and check my tyres :nerd:
Also very little noticable difference form 204 45 16 to 195 45 16's.
