mpg pd105 tdi bxe engine
Hi this is my first post so please bear with me
my octy tdi 2008 ambiente
is only doing 40 mpg around town and on motorway
I have new egr valve new maf
new turbo
a regualarly serviced engine all filters & oil changed every 10k
the engine is a recon  runs fine and has only done 40k
I have also replaced injectors and injector wiring loom
checked all vac lines all boost lines no leaks
checked for fuel leaks around pump no leaks
checked injector values in vcds all ok
torsion value is -2.7  could this be the reason for poor mpg?
any advice on torsion value???
There is a lot of debate on torsion value if you Google, there is no exact right or wrong answer it's trial and error as to what value is best for the particular engine, the sweet spot can pretty much be anywhere between -4 and +4. That being said, to start with, most try and line it up to -0.5 and take it from there. But yes it can have a fair impact on economy
When I first got my mk2, I could not get the mpg above low forties.
A couple of new tyres meant a 4 wheel alignment was needed (in MY service schedule at least). Trip home, computer showing mid fifties plus. So that was a win then.
The improvements in grip and handling were also most welcome.
The long term tyre wear - 40,000 from the set, was sufficient justification for getting the geometry properly checked.
When I had mine I was constantly getting high fifties around town and well over 60 on a run. As said it could be your driving style.
My 2009 BXE estate gets same MPG as reported by Stormchaser - anywhere between 50 and 60mpg averaged over a tankful.  Never had it drop below 50.
Reading around about the torsion value it can be very hit and miss and can even be down as low as -5.7 on some cars.
I'd say check the basics first. Check tyres, wheel alignment, turbo leaks, air filter, maf readings and then finally give it a good thrash.
I'm currently getting an average of 45mpg with mainly town driving. Even a fast Autobahn run will see just shy of 50mpg and mines a DSG so something's definitely not right with yours.
Phil
cured and sorted torsion value now at -1
found slight boost leak on the top hose because the idiot from our local stealers put the freking clip on the wrong way round d'oh lol
now up to 55 mpg yippee tested around town and on local bypass
tyres are fine 4 wheel alignment was done 3 weeks ago
driving style well I drive pretty gentle most of the time with the occasional thrash to exercise the turbo vanes!!
Edited by taximandorset
Cool.
How did you set your torsion value?
The best way is to try new values then monitor the idle stabilisation values with VCDS for when they get as near to the requested or 0 as possible it should be spot on.
If your idle is smooth then they are likely to be ok.
Phil
I have vcds for setting torsion value
idle values are seem to be ok as close to 0.0 as possible
idle is steady as a rock at 840 rpm.
Sounds good to me.
Hopefully it's sorted now then.
Enjoy!
Great news :)
Glad all is good now[emoji106]
I got 54mpg from my 1.9 TDI DSG
I average 43-46mpg calculated. Most miles are 7miles to work and 7 miles home, and the odd run at the weekends. Clear roads in the morning, rush hour going home!
I used to use vPower Nitro, but now just collect clubland points and haven't noticed a real difference in consumption. Seems my driving style is similar to yours taximan, I don't want things seizing because of buildups!
